Postavicu par slika, tehnicke karakteristike, pa da malo prodiskutujemo. Koliko znam Roki ga je probao, a ima ga i Mikka sa foruma, koji ne dolazi cesto, ali eto mozda se covjek javi da nam prenese neko direktno iskustvo. Nadam se da cemo svi biti realni, sto se tice licnih ocekivanjama i iskustva, posto su vlasnici BMW poznati po tome da imaju stav da ne postoji bolje od BMW-a
Dakle, BMW F 800 GS 2009
GENERAL
Model BMW F 800 GS 2009
Category All-road
ENGINE
Type 798 cc, water cooled, twin, 4-stroke
Bore x stroke (mm) 82 mm x 75 mm
Compression ratio 12:1
Valves DOHC, chain-driven with cam followers, 4 valves per cylinder
Fuel system Electronic intake pipe injection / digital engine management (BMS-K)
Power 85 hp (63.4 kW) @ 7500 rpm
Torque 83 Nm (61.2 ft. lbs) @ 5750 rpm
Lubrication system dry sump
TRANSMISSION
Clutch Multiple-disc clutch in oil bath, mechanically operated
Gearbox 6 speed
Ratios 1e 2.46, 2nd 1.75, 3th 1.38, 4th 1.17, 5th 1.04, 6th 0.96
Primary drive 1.94
Final drive Chain, 1.26
Starting system Electronic
CHASSIS
Frame Tubular steel space frame, load-bearing engine
Front suspension Upside-down front fork, Ø 45 mm, 230 mm travel
Rear suspension Cast aluminium dual swing arm, WAD strut (travel related damping), spring pre-load hydraulically adjustable (continuously variable) at handwheel, rebound damping adjustable, 215 mm travel
Rake / Trail 26 degrees / 117 mm (4.6 inches)
WHEELS
Wheels Wire spoke
Front wheel 2.15 x 21
Rear wheel 4.25 x 17
Front tyre 90/90-21
Back tyre 150/70-17
Front brakes dual 300 mm discs with 2-piston calipers
Rear brakes single 265 mm disc with 1-piston calipers
DIMENSIONS
Overall length 2320 mm (91.3 inches)
Overall width 945 mm (37.2 inches)
Overall height 1350 mm (53.1 inches)
Seat height 880 mm (34.6 inches)
Wheelbase 1578 mm (62.1 inches)
Fuel capacity - reserve 16 l (4.2 gallon US) - 4 l (1.1 gallon US)
Dry weight 185 kg (407.9 pounds)
