oprema motocikliste
VitaminC
Vozim: Aprilia Scarabeo
Re: oprema motocikliste
Post by VitaminC »
Bih danas tamo, sve malecne te ixs ali lijepo izgledaju.
Posle u Blok u Vg moto i kupim jednu finu, nije air mesh ali je tanka. Ima postavu takodje a i skidaju se rukavi pa moze kao prsluk da posluzi. Stitnike takodje ima.
Pogledajte ovu zanimljivu napravu
http://www.antigravitybatteries-uk.co.u ... -xp-5.html" onclick="window.open(this.href);return false;
Akumulator mi je vrisnuo pa zato gledam ovakve stvarcice :)
copy/paste
THE NEW MICRO-START XP-5
The NEW Micro-Start XP-5 "MINI" is the world's smallest Jump Starter and Personal Power Supply. In fact it is the size of Smart Phone, yet has so much power it can start your Motorcylcle (Excluding large V Twin's), But not only can it Jump Start your vehicles it can also charge any of your USB powered devices such as Smart Phones, , iPads, Tablets, Go Pro Cameras Blue Tooth Devices and more. It has 6000mah of capacity and has a peak of 300 amps for jump starting!
Just charge it once and take back-up power where ever you go. No need to a power outlet, or charging station. Weighing 8 ounces and as big as a Cell Phone you can take it anywhere ! Whether you are riding, driving, camping, traveling anywhere you can remain confident that you will be able to start your vehicle, or make that important call if you battery is going dead on your cell phone. It even has a built in flashlight with S.O.S patterns built in! Whatever you do, don't get stuck without back up power again....
THE MICRO-START XP-5---- WHAT IS IT AND WHAT CAN IT DO?
The XP-5 is the worlds the smallest lihium-ion Jump Starter/Portable Power Supply available:------- only 5” x 2-7/8” x 1/2”, and only 8 oz.
It can Jump start Cars, Trucks, Motorcycles, ATVs, UTVs, Snowmobiles and Watercraft--- and YES it will jump start your V6 truck!!!
It Charges and Powers all electronic devices such as--- Cell Phones, iPads, iPhones, Kindles, PSPs, PDAs, GPS, MP3s, Blue Tooth Devices, Cameras and more that use USB 5v charging Standard
It has 2 on-board Power Ports: A Jump Start Port, and a USB 5v 2,1 amp output for charging or powering 5v USB charged devices.
It has a LED flashlight with 2 built-in flash patterns including an S.O.S. flashing beacon pattern.
It has a lighted battery capacity indicator- Press a button to see the battery capacity left in the Micro-Start
It has built-in over-charge and over-discharge protections for long battery life
It has an automatic power-off when not in use
The Micro-Start XP-5 model comes with:
Carry Case with all tips and attachments for Jump Starting, Charging electronics and charging the XP-5 Unit
Micro-Start XP-5 Unit
Detachable Mini Jumper Clamps
1 White Universal USB Cable with 4 of the most common tips for Cell Phones and other Electronics to 5v USB chargeable electronics such as all Cell Phones, iPads, iReaders (Kindles), PSPs, GPS, tablet computers, and anything else using the 5V USB standard (Mini USB, Micro USB, Apple 8 pin, Apple 30 pin connectors)
1 Home Charger (3 pin 240 volt UK)
1 Mobile Charger for plugging into cigarette lighter socket
SPECS
150 Amp- 300 Peak Amp Jump Starting ability
8 ounces
5" long x 2.8" wide x 1/2" tall
Grk na hu meni i fiki pokaza nesto slicno...
reca da je jedbom auto upalio na tu bateriju :shock:
Vozim: Honda XR 600 R
Buell XB12X
Post by jovan »
DrMracni wrote: (Excluding large V Twin's),
Ne gledaj ovaj model, izgleda da nije namijenjen za start velikih V2 agregata kao što je 990. Gledao sam ovih startera većih dimenzija, dosta težih od ovoga i veće snage. Praktična i veoma korisna baterija, pogotovo na putovanjima. Ovaj model je zanimljiv zbog malih dimenzija i male težine, ako su tačni podaci o startnoj struji i kapacitetu onda je ovo dobra baterija i veoma upotrebljiva.
Pejamachine
Post by Pejamachine »
Ivo, ol moj akumulator, ja bih kupio litijumski.. :)
Sent from my HTC 10 using Tapatalk
