Yamaha MT-07
Yamaha MT-07
Najvjerovatnije još jedan model iz MT familije. Broj cilindara, kubikaža, ma sve ostalo je nepoznato, a znaće se na milanskom sajmu ...
Re: Yamaha MT-07
Jeste, novi član familije MT, a ovaj ima dva cilindra, 689 ccm i 75 KS ... Uskoro opširnije
Re: Yamaha MT-07
Dizajnerski se oslanja na većeg brata MT-09. U pitanju je novi dvocilindrski motor za koji iz Jamahe tvrde da će prestavljati novu referencu u zabavi.
Tehnički podaci za Yamaha MT-07:
Motor: R2
Zapremina: 689 ccm
Snaga: 75 KS pri 9.000 o/min.
Obrtni moment: 68 Nm pri 6.500 o/min.
Mjenjač: -
Visina sjedišta od tla: 80,5 cm
Težina spremnog za vožnju: 179 kg / 182 kg sa ABS-om
Rezervoar: 14 litara
Re: Yamaha MT-07
u ram od xt660z :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray: :pray:
