Ideje za putovanja
velimlje
Re: Ideje za putovanja
Post by velimlje »
Prelazi izmedu 1500 i 2000 metara
Arlbergpass , A , 1793 , 13% , Bludenz - Landeck
----- napomena - tunel na visini 1318 koji se naplacuje
Passo del Brocon , I , 1616 , 11%
Passo Campo Carlo Magno , I , 1682 , 11%
Passo di Campolongo , I , 1875 , 12%
Col de la Colombiere , F , 1613 , Cluses - Le Brand Bornand
Passo di Kostalunga ili Karerpass , I , 1753 , 16%
Col de la Croix Haute , F , 1778 , 12%
http://www.alpentourer.com/alpine_passe ... croix.html" onclick="window.open(this.href);return false;
Flexenpass , A , 1773 , 10%
http://www.alpentourer.com/alpine_passe ... npass.html" onclick="window.open(this.href);return false;
Col de la Forclaz , CH , 1528 , 8% , Martigny - Le Chatelard ( F )
http://www.alpentourer.com/alpine_passe ... rclaz.html" onclick="window.open(this.href);return false;
Gampenjoch ili Passo della Palade , I , 1518 , 9%
http://www.alpentourer.com/alpine_passe ... njoch.html" onclick="window.open(this.href);return false;
Hahntennjoch , A , 1903 , 15%
Hochtannberpass , A , 1679 , 14%
http://www.alpentourer.com/alpine_passe ... gpass.html" onclick="window.open(this.href);return false;
Katchbergpass , A , 1641 , 15% , naplacuje se
Klausen Pass , CH , 1948 , 10% , Altdorf - Linthal
Krauzberger ili Passo di Monte Croce di Comelico , I , 1636 , 12%
Colle della Maddalena ili Col de Larche , F - I , 1991 , 12% , Barcelonnette - Cuneo
Passo di Lavaze , I , 1818 , 15%
Passo del Lucomagno ili Lukmainerpass , CH , 1940 , 10% , Disentis - Bisca
http://www.alpentourer.com/alpine_passe ... rpass.html" onclick="window.open(this.href);return false;
Malojapass , CH , 1815 , 12% , St.Moritz - Chiavenna
http://www.alpentourer.com/alpine_passe ... apass.html" onclick="window.open(this.href);return false;
Col de Montgenevre , F - I , 1850 , 12%
Nassfeldpass ili Passo di Pramollo , A - I , 1552 , 12%
Col du Pillon , CH , 1546 , 11%
http://www.alpentourer.com/alpine_passe ... illon.html" onclick="window.open(this.href);return false;
Radstadter Tauernpass , A , 1739 , 15%
Passo di Rolle , I , 1973 , 11%
Passo di San Pellegrino , I , 1920 , 14%
Col de Sant Angelo , I , 1756 , 11%
Solker Pass , A , 1788 , 12%
Col de Tende , I - F , 1321 ili 1870 , 11% , Nice - Tende - Cuneo
---- tunel je napravljen na visini 1321 jos 1882 godine , stari put jos postoji ali nisam siguran dali je asfalt …
Passo del Tonale , I , 1883 , 10%
http://www.alpentourer.com/alpine_passe ... onale.html" onclick="window.open(this.href);return false;
Passo Tre Croci , I , 1809 , 12%
Turracher Hohe , A , 1783 , 23% :D :D :D :D :D
Croix de Valberg , F , 1673 , 10%
Vrsic Sedlo , SLO , 1611 , 14%
Wolfgangpass , CH , 1637 , 10%
velimlje
Post by velimlje »
Evo , kao sto sam i obecao , moj drug iz mladosti , Amadeo dozvolio mi je da upotrebim nekoliko njegovih slika sa nedavne ture , koje je postavio na Facebook
Mozda , ako ga malo gnjavim , postavi i putopis , ko zna
Inace , pozeleo sam da postavim njegovu turu ovde , jer mislim da je jako lepo isplanirana , a polazi sa nase strane , za razliku od svih mojih tura , koje polaze sa ‘’pogresne’’ strane…
Amadeo je kretao nekako ovako , snaci cete se , verujem ..
Iz Slovenije u Italiju
Lago di Misurina
prelaz Passo Falzarego
prelaz Passo Pordoi
prelaz Passo dello Stelvio
prelaz Passo Foscagno
Livigno
St.Moritz
prelaz Julierpass
prelaz Oberalppass
prelaz FurkaPass
prelaz Col de Forclaz
vrh Evrope - Mont Blanc
Chamonix
prelaz Col de Saisies
prelaz Cormet de Roselend
Passo di Mauria -- ovo ne izgleda u redosledu
Val d Isere
prelaz Col de l’Iseran
Valloire
prelaz Col du Galibier
prelaz Col d’Izoard
prelaz Col de Vars
prelaz Col de la Bonette
Grase
Verdon gorge
i posle kroz Provansu , okrenuvsi se natrag , Monte Carlo i natrag kuci …
velimlje
Post by velimlje »
Evo i nekoliko slika , uz Amadeovu dozvolu , na cemu mu se zahvaljujem..
velimlje
Post by velimlje »
Evo i drugi deo slika …nadam se da vam se svidaju ..
Aferim
Vozim: versys 1000
Post by bokibd »
uuuuff, jos 6 dana i krecemo. Samo mi nabijas adrenalin sa ovim slikama. Ne mogu docekat. :lol:
velimlje
Post by velimlje »
Da nastavimo gde smo stali
Obradili smo prelaze u Alpama , spisak prelaza u Pirenejima cu da obradim neki drugi put
Znaci , necu da pisem o gradovima i ostalim , poznatim turistickim destinacijama . Za tako nesto trebalo bi mnogo vise mesta , plus obicno ili vec imamo neku zelju gde da idemo ili bolja polovina pozeli da ode u Pariz , Monako ili Grcku na more.
Polazim od predpostavke da turu generalno imate u glavi , ja se samo trudim da vam skrenem put do neke interesantne destinacije uz put .
Sledi spisak , koliko sam to mogao da iztrazim , kanjona , prirodnih lepota i slicno , po drzavama
Probao sam da izbegnem ona mesta koja su lepa a nepristupacna , pa sam najvise trazio kanjone kroz koje prolazi put ili bar dolazi u blizinu . Nazovite me lencugom , nama problema … :D
Pogotovu kad je rec o kanjonima , jer je tesko definisat sta se racuna kao dubina , i koji je uzi ili vislji , postoje razne teorije i prepucavanja , ali vecina sajtova pominje Vicos kanjon u Grckoj , koga forsiraju na toj listi Grci i Englezi , kanjon reke Verdon , koga forsiraju Francuzi i kanjoni Tare i Rakitnice kod nas …. kao najduze i najdublje kanjone
Namerno necu da pisem o Srbiji i Crnoj Gori , jer sigurno vecina vas zna taj deo bolje od mene , pa slobodno kad stignete dodajte nesto interesantno ili manje poznato .
DA NAPOMENEM - SVE fotografije ovde su sa interneta !!
velimlje
Post by velimlje »
Bugarska , Rumunija
Kanjon Trigrad
kanjon je okomitih granitnih stena u Rodopskim planinama , na jugu Bugarske . Litice kanjona dizu se 300 -350 metara iznad reke Trigrad , sirina od 300 do 100 metara , a nalazi se nadomak sela takode nazvanog Trigrad …
Kanjon Bicaz
ili rumunski Cheile Bicazului jedna je od najspektakularnijih destinacija u Rumuniji . Nalazi se na severo istoku zemlje izmedu pokrajina Moldove i Transilvanije . Put duzine 8 kilometara smatra se jedan od najlepsih puteva u Rumuniji i sire
velimlje
Post by velimlje »
Grcka
Kanjon Samaria na otoku Kritu
Grci , izgleda ko i mi vole da preteruju , pa se hvale da je to najduzi kanjon u Evropi , sto nije tacno . Ali to ne znaci da nije lep . Put vodi duboko u kanjon , ali da bi videli najinteresantniji deo , morat cete malo prosetat ….
Nalazi se u Belim planinama nedaleko grada Chania , duzine je 16 kilometara , a ne 18 ko sto pola interneta kaze ( Grci reklamu ozbiljno shvatili :D ) visina sa severa 1250 metara
Najlepsi deo kanjona su takozvana Iron Gates , ili Zeljezna Kapija gde se kod sirine kanjona od 4 metra zidovi dizu skoro okomito do 500 metara visoko
[youtube]http://www.youtube.com/watch?v=Rb8pROr_PG4&feature=related[/youtube]
Kanjon Vicos
po Ginesovoj knjizi rekorda najdublji kanjon na svetu . Nalazi se u planinama Pindus na severu Grcke , duzine je 20 kilometara , sirine od nekoliko metara do 400 metara
Kanjon Imbros na otoku Kritu
Duzine 11 km , blizu Hora Sfakion na jugu otoka , paralelan je Kanjonu Samaria , na najuzem delu sirina je samo 1,6 metra a u kanjonu se nalazi put koji za razliku od obliznjeg kanjona Samaria ide dnom kanjona , pa je verovatno zato zanimljiviji za setnju , naplacuje se ulaz i put nije tezak za hodanje
Kotsifos kanjon otok Krit
Sve ostalo je manje vazno , pogledajte put ….
Meteora
O Meteori smo vec pricali , samo da pomenemo nekoliko informacija
Meteori se nalaze blizu gradica Kalambaka u centralnoj Grckoj , blizu Pindus planina , tako da vam ni kanjon Vicos nije daleko … Neke od stena , na kojima se nalazi 6 manastira uzdizu se do 550 metara iznad pokrajine
Negde sam procitao da je prilaz lepsi iz pravca Ioannine
Slika , nadam se nije potrebna …
velimlje
Post by velimlje »
Svajcarska
Svajcarska ima nekoliko predivnih kanjona , preuskih za put , sa stazama za setanje , samo da pomenem dva
Gorges du Trient klisura duboka 200 metara sa vodopadom visine 114 metra na kraju blizu gradica Vemayaz u podnozju Mont Blanca , blizu Francuske granice
The Aar Gorge ili jer je to nemacko govorno podrucje [/b]Aareschlucht[/b] blizu grada Meiringen , a dodatno moze da vas privuce i Reichenbach vodopad na istoj reci , visine 250 metara
Ako ste , ko ja , vise razpolozeni za voznju kroz kanjon , pogledajte dali vam se svida ova slika
Kanjon Ruinaulta , kroz kojeg prolazi put gradova Bonaduz i Ilanz , evo jedna slika
A ako se zaputite na prelaz Gotthard , izmedu Goschanen i Andermatt nalazi se Schöllenen Gorge
Put deli kanjon sa zeleznicom , a od nekoliko mostova najpoznatiji je Teufelsbrucke ili Davolji most
U kanjonu cete naci i spomenik Ruskom generalu Suvorovu
Jedna od destinacija koja je bar meni plan vec duze vremena , ali je za obilazak potrebno verovatno malo vise vremena je takozvana Dolina vodopada u kojoj se nalazi selo Lauterbrunnen
Iza sela mozete da vidite jedan od poznatijih vodopada , Staubbach visine 300 metrara
citava dolina , u kojoj se nalazi cak 72 vodopada je poznata po svojim skoro okomitim stenama koje je zatvaraju , pa je zato to poznato okupljaliste base-jumpera
U istoj dolini naci cete i Trummelbach vodopade , serija od deset glecerskih vodopada u steni planine , a oko njih izkopani su tuneli i prolazi da bi jim se moglo prici ..
Sam vodopad Trummelbach nosi vodu sa glecera Eigera , Moncha i Jungfraua i jedini je glecerski vodopad u planini koji je dostupan u Evropi . Kazu da godisnje sa glecera prode 20000 tona kamenja i ostalog materijala sa brda iza , a protok je cak do 20000 litara u sekundi !! Na listi je UNESCO-a
Kad vec pominjemo vodopade , nemojte zaobici najvece u Evropi , po protoku vode
Rhinefall kod Schaffhausen-a
Sirina 150 metara , visina 23 metra , prosecni protok vode u letu 700 kubnih metara u sekundi !!
Pomenuli smo vec kratko glecere kod prelaza , ali evo dva
Znaci Rhonegletscher je onaj pored prelaza Furka Pass
Izgleda da sam pobrkao loncice kad sam pre pisao o tome , pa evo da ponovimo , posto znam da se
Rajna kako je zovemo mi preko Rhinefall koje smo pomenuli ranije , spusta kroz Nemacku u Severno more
A Rhone kojoj neznam nase ime izvire tu , kod Furka Passa , tece u jezero Geneva i posle u Sredozemno more , u Francuskoj ..
Nema veze , ovako izgleda
A najveci glecer Svajcarske Aletschgletscher , ujedno i najveci glecer Alpi , sa 120 kvadratnih kilometara povrsine nalazi se u kantonu Valais
