Firma je osnovana 1971 u Italiji,ali je propala 84',da bi je ponovo digli iz mrtvih dvojac,kineski biznismen i Husqvarnin inzinjer,svetskog glasa...
Iako mi djelovase kao jos jedan "kinez" u nizu,ipak komponente koje se ugradjuju daleko su od kineskih...
Model RS 650 R je saraf u saraf husqa TE 630,i cijena mu je oko 8000 e
U ponudi imaju 125,250,300,340 i 500 ccm modele...
Na papiru djeluje mnogo dobro(osim ovoga hoda prednjeg amortizera
SPECS: 2016 SWM RS 650 R
ENGINE
Type: Liquid-cooled four-valve single cylinder
Capacity: 600cc
Bore x stroke: 100.1mm x 76.5mm
Compression ratio: 12.4:1
Fuel system: Electronic fuel injection
PERFORMANCE
Claimed maximum power: 53hp
Claimed maximum torque: N/A
TRANSMISSION
Type: Six speed
Clutch: Wet multi-plate
Final drive: Chain
CHASSIS AND RUNNING GEAR
Frame: Steel double-cradle
Front suspension: Upside-down Marzocchi, 210mm travel
Rear suspension: Sachs monoshock, 269mm travel
Front brakes: Twin 260mm discs with twin-piston Brembo calipers
Rear brake: 220mm disc with single-piston Brembo caliper
DIMENSIONS
Claimed dry weight: 144kg
Wheelbase: 1506mm
Ground clearance: 249mm
Seat height: 899mm
Fuel capacity: 12 litres
